Spyderco Manix 2 XL SALE! $103.46 Shipped USA!
Feedback: +1 / =0 / -0
Our Spyderco Sale Continues!
Spyderco Manix 2 XL C95G2, Plain Edge
Suggested Retail: $194.95 Sale Price: $103.46 You Save: $91.49
http://www.knifeworks.com/spydercomanix2xlc95g2plainedge.aspx#.VQMefRvwvIU
The large Manix2 is an oversized version of the Manix2 with a blade that is just under four-inches. The blade is locked open using Spydercos patented Ball Bearing Lock. The lock is comprised of a free-floating steel ball-bearing encased in a high-tech polymer cage. When opened, the ball bearing moves forward onto the blades ramp where it is wedged, locking the blade safely open.
The spherical shape of the ball rotates freely allowing the lock to self-adjust across a large surface, ensuring smooth and confident lock-up every time it is opened. The blade is CPM-S30V, ground full-flat and features jimping above the oversized 14mm Spyderco Round Hole. The jimping texture continues from the blades spine to the full-length skeletonized steel liners.
The liners inside the G-10 handle extend beyond the scales, creating a scalloped pattern around the handles perimeter for additional grip. This feature keeps the knife from slipping out in the hand and works well with gloves. The liners serve a double purpose by adding rigidly and lightweight strength to the handle. A three-screw clip can be positioned ambidextrously, tip-up for comfort and pocket carry. The knife also has a large lanyard pipe to protect various types of cords or thongs.
length overall 8.94" (227 mm)
length closed 5.1" (130 mm)
hole diameter .56" (14 mm)
blade length 3.86" (98 mm)
cutting edge 3.44" (87 mm)
blade thickness .125" (3 mm)
blade steel CPM-S30V
weight 5.9 oz (168 g)
handle material G-10
