Spyderco Native 2 C41PS
Feedback: +3 / =0 / -0
This is a never carried never used AU-10 spyderco folder......
Description
You can slice away with style with the Spyderco C41PS Native AUS 10 Handle Combo Edge Blade Knife. Lightweight and versatile, it's an all-around perfect choice for simplicity and function.
The Native was ergonomically designed for the human hand to minimize discomfort and fatigue. The stainless steel handle has two finger choils for versatility. One gives you closer proximity to the blade for controlled cutting, and the other puts your hand further back for pushing cuts away from you. It's chamfered smoothly with no rough corners for an easy grip and fit. The flat, stainless surface provides the perfect place for engraving to really make this knife your own.
The 3.13 inch combo-edge AUS 10 blade is hollow-ground giving you versatile, functional performance in a variety of applications. It features an ambidextrous clip for easy tip-up carrying. Stylish and functional, the Spyderco C41PS Native AUS 10 Handle Combo Edge Blade Knife will definitely be your go-to choice for all your cutting needs. Put one in your cart and start slicing away!
Specs: Blade Steel AUS-10 Blade Thickness 1/8" 3mm Clip Reversible Ambidextrous, Stainless Steel Diam. Blade Hole 15/32" 12mm Edge Type 50/50 Handle Material Stainless Steel Hardness 58-59 Length Blade 3 1/8" 80mm Length Cutting Edge 2 5/8" 66mm Length Overall 7" 178mm Weight 4.6oz 131g
CONUS. PayPal only. No trades. $75 OBO.
ImageUploadedByTapatalk1400549647.750031.jpgImageUploadedByTapatalk1400549655.327975.jpgImageUploadedByTapatalk1400549661.957561.jpgImageUploadedByTapatalk1400549668.466942.jpg
