- Dec 19, 2002
NOW IN STOCK AND SHIPPING !
Spyderco Para-Military 2, Camo G-10, Plain Edge
Suggested Retail: $189.95 Our Price: $108.95 You Save: $81.00
http://www.knifeworks.com/spydercopara-military2camog-10plainedge.aspx
Why change something if it works? Because, at Spyderco, we practice the principle of C.Q.I. - Constant Quality Improvement. If we can refine and improve the ergonomics or cutting performance of an established model, we do it.
Our 2010 Para-Military2 has several changes over the classic version. The G-10 handle is narrowed at the end improving the ergonomics. The handle and blade have been profiled thinner; removing uncomfortable angles when in the closed position. It features a Compression Lock and an ambidextrous-friendly four way clip which carries tip-up/tip-down, left/right-hand and rests deeper in a pocket. We kept the same high-performance CPM-S30V full flat-ground blade but weve also lengthened the blades tip and added additional surface jimping to both the spine and finger choil. Implementation of a new Bushing Pivot System generates fluid action and more consistent manufacturing tolerances. Larger lanyard gives more options for carry.
Refinements to overall construction may not be drastic or even visible to the eye but from the G-10 textured handle to the CPM-S30V steel full flat blade, everything is sharper, smoother and guaranteed to provide performance and user comfort.
Made in Golden, Colorado U.S.A.
Features
4-way clip : Tip up/down, left/right hand
Nested Compression Lock
G-10 Laminate Handle Scales
Spine & choil Jimping
Screw-together construction
14mm Spyderco Round Hole (for gloved hand)
Modified clip-point flat-ground blade
Specifications:
Closed Length: 413/16 in.
Overall Length: 8 9/32 in.
Blade Length: 3 7/16 in.
Edge Length: 3 5/64 in.
Blade Steel: CPM-S30V
Weight: 3.75 oz.
Product Reviews
Outstanding
Dorothy Mantooth (Northwest) 2/26/2014 7:30 PM
If you are reading this you're already aware of the superb reputation this knife has. I would say the hype is certainly justified. Having owned about 20 "higher-end" knives, this one takes the cake for most comfortable, aesthetically pleasing, & razor sharp blade. Also the price on Knifeworks happens to beat the top knife sites bar none. Highly recommended.
Well worth it, again
Joey (Louisiana) 9/3/2012 8:18 AM
I have used this s30v blade for 2 weeks and have not sharpened it once. The G10 handles are more "grippy" than the tenacious model. I cannot do justice in an explanation on how smooth the blade is to open and close. All the hype on this folder and I cannot criticize! Buy one and see for yourself.
Features
Specifications:
Weight: 3.75 oz.
Product Reviews
Outstanding
