- May 24, 2004
I'm bored, so I'll do some comparisons between my black plain edge Spyderco Paramilitary and my satin plain edge Benchmade 710. It is be better if I compared the 710 to the full sized military, but I don't have a full sized military so
about me: I am not a special forces ninja or an extreme outdoorsman. I'm just a guy who likes knives and uses them for simple tasks such as cutting wrapping paper. If I want to pry something, I use a crowbar.
Blade
The Para Milie is S30V and the 710 is D2. I don't abuse my knives so I can't give any testing on the blade hardness or edge retention. Both can shave hairs but that ain't saying much. Both the para milie and 710's blade shape are utilitarian, so it is a tie.
Lock
The Para Milie has a compression lock and the 710 has an axis lock. Again, I don't abuse my knives so I don't know which lock is tougher. Both locks lock up solid for normal situations. I like the axis lock better than the compression lock because my fingers can be out of the blade's way when closing the knife. Also, the axis lock allows me to flip open and close the 710. It is not to say the compression lock is a bad lock but the axis lock is just cooler to play with. Like the compression lock is probably safer than the axis lock because it is less likely to be accidentally disengaged since the compression lock is only exposed at one side and is partially shielded by the hand. Winner:710
Ease of opening
Hmm... it is gonna be a tie. The para milie's hole is easier to open than the 710's thumbstuds, however, the 710's axis lock allows it to be smoothly opened by gravity and the 710's tension can be easily adjusted. Both knives can be flipped open. But without using the axis lock to open, the para milie is a smoother opener than the 710. tie
Ergonomic
I like the Para Milie's ergonomic better than the 710. The para milie has a finger coil for detailed cutting and acts an extra safety device just in case the lock fails. The 710 has neither. Oh, I'm not left handed so I don't care about left handedness (in that case the 710 will win) Winner: Para milie
G10
The para milie's G10 is the clear winner. 710's G10 is smooth and slick while the para milie's G10 is like sandpaper. Winner: Para milie
Ease of cleaning
Para milie wins this too because there are no space between the handles, so you can just blow lint out. For the 710, you have to scoop the dirt out between the handles. Winner: Para milie
Ease of carrying/discreetness
710 rides lower and feels less intrusive in the pocket than the para milie due to the 710's thinner profile. The 710 is tip up and the para milie is tip down. I prefer tip up, so the winner is the 710
Novelty
Spyderco's "Golden Colorado, USA, Earth" is pretty funny. The spyderco bug looks cuter than the benchmade's butterfly. winner: pare milie
Overall
Both the 710 and para milie are great knives. As I stated earlier, a better comparison would be between the 710 and the full sized military. Since I don't need a big knife for normal EDC, I declare the para military as the winner. However, both the para milie and 710 can learn from each other. The 710 can have a gripper G10 and an open space between the handles to improve the ease of cleaning.The para milie can have a lower riding clip (the axis lock is debatable).
Blade
Lock
Ease of opening
Ergonomic
G10
Ease of cleaning
Novelty
Overall
