SPF*********
This is a very light user version of a Cutlery Shoppe exclusive. It opens like it is on glass and holds a great edge, It has a great look and is all original. This is not a fake, a clone, or some other second quality knife. Comes with original box and paper.
The below description is from the Cutlery Shoppe website with all credit to them and their creative content. Pictures are mine and of the actual knife for sale. Asking $200.00 obo shipped priority insured within the entire United States and territories. This is a straight up paypal or money order payment, no fees to you.
Thank you for looking,
Cutlery Shoppe Exclusive Para 2
Why change something if it works? Because, at Spyderco, they practice the principle of C.Q.I. - Constant Quality Improvement. If they can refine and improve the ergonomics or cutting performance of an established model, they do it.
This Para 2 has several changes over the classic version. The G-10 handle is narrowed at the end improving the ergonomics. The handle and blade have been profiled thinner; removing uncomfortable angles when in the closed position. It features a Compression Lock and an ambidextrous-friendly four way clip which carries tip-up/tip-down, left/right-hand and rests deeper in a pocket. This Cutlery Shoppe Exclusive version features a premium CTS-XHP full flat-ground blade, which is given a black DLC (Diamond Like Coating) finish. Spyderco has also lengthened the blade's tip and added additional surface jimping to both the spine and finger choil. Implementation of a new Bushing Pivot System generates fluid action and more consistent manufacturing tolerances. Larger lanyard gives more options for carry. Refinements to overall construction may not be drastic or even visible to the eye but from the G-10 textured handle to the CTS-XHP steel full flat blade, everything is sharper, smoother and guaranteed to provide performance and user comfort. This limited edition of 1,200 pieces is made in Golden, Colorado U.S.A exclusively for Cutlery Shoppe customers.
Specs:
Blade Steel: CTS-XHP
Handle Material: Orange G-10
Length Open: 8 9/32" (210 mm)
Blade Length: 3 7/16" (87 mm)
Length Closed: 4 13/16" (122 mm)
Hole Diameter: 9/16" (14 mm)
Blade Thickness: 9/64" (3.5 mm)
Weight: 3.75 oz. (106 g)
Made In: USA
More about CTS-XHP steel:
Carpenter Steel Company is enjoying a hospitable welcome from knifemakers and manufacturers. Well known for their performance automotive, aerospace, energy, medical, defense, and consumer products industries steels, they recently began offering high-performance blade steels. CTS-XHP is air hardened, high carbon and high chromium with corrosion resistance similar to 440C-type steels and with hardness qualities found in tool steel. Its edge retention, ability to be machined to a fine edge, and consistent heat-treatability make it perfect for this exclusive Sprint Run.
Specs:
Made In: USA
