DA170
Platinum Member
- Mar 12, 2020
Spyderco Para Military 2 - 3.45" CPM-REX 121 Black ZrOC Blade Finish Wharncliffe Blade - HEX Pattern Orange G-10 Scales - CUTLERY SHOPPE EXCLUSIVE - C81GPWCORRX121BK2 $285.00
Drop 04/17 @ 10AM Mountain TimeThis Cutlery Shoppe exclusive version of the PM2 is the ONLY one that will ever feature a Crucible Industries CPM REX 121 blade. This special edition is also the first offering from Spyderco with their new VaporTech ZrOC (zirconium oxycarbide) blade finish.
- Specs:
- Category End Use: EDC/Collector
- Blade Steel: CPM REX 121
- Blade Grind: FFG (full flat grind)
- Blade Length: 3.45" (88 mm)
- Length Open: 8.26" (210 mm)
- Length Closed: 4.82" (122 mm)
- Blade Thickness: .145" (3.7 mm)
- Hole Diameter: .5" (13 mm)
- Lock Type: Compression
- Scale Material: Orange G-10
- Scale Pattern: Cutlery Shoppe Exclusive HEX
- Tip Carry: Tip-Up/Down
- Clip Position: Four Way
- Weight: 3.8 oz. (108 g)
- Made In: U.S.A.
More about CPM-REX 121 steel
Crucible Industries’ CPM REX 121 is a high-vanadium, cobalt-bearing tool steel designed to offer the greatest wear resistance and attainable hardness in a high speed steel. Created to bridge the performance gap between high-alloy tool steels and carbide materials in demanding industrial applications, when applied to knife blades, REX 121 offers extreme hardness and unequaled edge retention.
