Spyderco ParaMilitary 2 S90V Sprint Run
Feedback: +11 / =0 / -0
The Para-Military 2 has several changes over the classic version. This Limited Carbon Fiber handle is narrowed at the end improving the ergonomics. The handle and blade have been profiled thinner; removing uncomfortable angles when in the closed position. It features a Compression Lock and an ambidextrous-friendly four way clip which carries tip-up/tip-down,left/right-hand and rests deeper in a pocket. This LIMITED SPRINT run comes with high-performance S90V full flat-ground blade. They've also lengthened the blade's tip and added additional surface jimping to both the spine and finger choil on the new Para2. Implementation of a new stepped pivot system helps generate fluid action and more consistent manufacturing tolerances. Larger lanyard gives more options for carry.
Refinements to overall construction maynot be drastic or even visible to the eye but from the Carbon Fiber textured handle to theS90V steel full flat blade, everything is sharper, smoother and guaranteed to provide performance and user comfort in this limited refined piece. Only 700 made, BNIB Mint selling for $450
length overall: 8.281 " (210 mm) blade length: 3.438 " (87 mm) blade steel: S90V length closed: 4.812 " (122 mm) cutting edge: 3.078 " (78 mm) weight: 3.75 oz. (106 g) blade thickness: .141 " (3.5 mm) handle material: Carbon Fiber
Tags Benchmade, zt, zero tolerance, shirogorov, gerber, sog
