Blop said:
Hi Buzz,
reading your SnG review i was surprised, that you were looking for a stronger tip, because most of the time you liked the fine tip more.
Now, everything has come back to normal!
Considering the paras finish, i think there are better finished production knives and Spycerdo could spend an extra on the spine. I disliked the choil for the small finger at the end of the handle and (in that passaround) i thought, if that should be mine, i would try to dremel the back for more comfort.
If someone can stand that tip, the para is a very well made knife and as a lefty a came around with the compression lock greatly.
I don't think that I mentioned wanting a stronger tip on the SNG. I did say that people who plan on prying might want the stronger tip of the tanto model. I don't pry, but I know that others have more need of a stronger tip than I do. That's why I mentioned it. I was just trying to cover all bases, and not mislead people into thinking that my SNG had an extremely broad tip.
Compared to the Para, the Strider definitely has the stronger tip. The shape of the spine on the SNG adds quite a bit more steel to the tip. But given the thickness of the blade, the full flat grind, and the taper at the tip, I certainly wouldn't categorize the SNG's tip as being "broad". Its a reasonably fine tip, but not as delicate as the Paras.
For my hand, the hook at the butt end of the handle worked very well. The fold of my pinky finger rested quite nicely on it, actually adding to the grip. If it weren't for that hook, I think that the butt end would have been too loose in my hand. For other shaped hands, I could see that hook as being bothersome though. I've heard similar complaints about the hook on the Manix, although the Manix allows for a MUCH larger hand before the hook becomes an issue.
At least the nested nature of the Para's liners allows for easy Dremel modifications to the handle shape. Reshaping of the handle would be much tougher on a folder with full liners.
Ideally for me, the mid-handle swell would have progressed right into the hook of the handle, leaving no hook and a wider overall handle at the butt. Unfortunately, that would require adding to the handle and not subtracting, so no Dremel mods for me.
tkknife - The SNG is definitely a great folder. Styling is exceptional. Performance is excellent. For people who aren't bothered by sharpening choils, the SNG is a no-brainer for medium-sized EDC. Its easy to see why somebody would prefer the SNG over the Para.
As it happened, I received an unintended tan handle on my SNG. There was an apparent mix-up in the phone conversation with my vendor. I thought that Id ordered the green handle, and ended up receiving the tan. I was a little disappointed at first, but the tan has really grown on me. The tan takes on a nice worn looking hue after a bit of use, which I find attractive.
