- Sep 20, 2015
Consider : stainless steel sheet metal (the liners) makes an excellent heat sink and there are two of them. Maybe the heat is dissipating faster than you think.I did crank the temp up a little bit and still nothing.
I don't know how Spyderco will deal with this but if you REALLY want this done rather than "really" then maybe it is worth the try. The worst part of it isn't going to be the letter but the wait; could be a couple weeks or so.
Here is one other thing you can do if you happen to have a drill press :
- get a good torx bit like a Bosh
- put it in the drill press chuck and tighten it well (put the wrench in all three holes; no body ever does that)
- DO NOT TURN ON THE DRILL PRESS
- lower the bit into the screw and hold the bit firmly in the screw socket with the downward force of the drill press handle
- put a 1/4 inch wrench on the bit to turn it
- (you can clamp something to the drill press table to act as a stop to keep the knife from rotating with the bit.
alternatively you could do this in the jaws of a largish bench vise but it turns into kind of a balancing act.
PS: it helps to touch the end of the bit on a turning bench grinder to get the most bite out of the end of the bit.
PPS: I know the bit will probably just spiral or break off but with larger bits this works really well.
