When are you going to post pics of that William Henry?
Nice buy. That is my favorite folder. Love the ergos and like you said- nasty sharp!
Great decision! I love my Sage II.
I'd suggest putting a mirror polish on the back bevel, and thinning out the edge. My Sage II cuts beautifully now.
The blade however doesn't open as smooth as my Sage 1. I wonder, could it just need some lube or maybe the pivot screw needs adjusting?
The primary grind is the the majority of the knife. On the Sage II it is a full flat grind, basically the blade is ground from the spine of the blade up to the back bevel. The back bevel is where the grinder increased the angle to grind in towards the edge. The micro bevel is the edge itself.
The Sharpmaker has two angle set on it, 30 degrees and 40 degrees. The 40 degree angle is meant for the edge, while the 30 degree angle is meant for the back bevel.
I'd put up pics, since it's easier to explain that way, but I don't have a camera right now.
By polishing the back bevel, it smooths out the surface of the knife. That way there is less friction when you are cutting things, making slicing much smoother. By thinning out the edge, you take off enough steel that you can decrease the angles of the back bevel and microbevel. The thinner the edge, and the more acute the angle of the microbevel, the sharper your knife is (assuming that you don't leave any burrs on the edge).
And now that you've handled it, it'll go back in the box to sell off for a sebenza! lol
