SPYDERCO SALE
1.) Spyderco Tenacious G-10 (3.375" Satin Plain) C122GP
The mid-sized Spyderco Tenacious C122GP has a satin finished blade with a plain edge and a black G-10 laminate handle, milled with prolonged fatigue-free cutting in mind. Tucked inside are skeletonized steel liners increasing the handle’s rigidity and strength without adding non-functioning weight or bulky thickness. The 8Cr13Mov stainless blade is leaf-shaped and ground flat from spine to cutting edge for cutting performance. The blade’s shape coupled with an over sized Spyderco Round Hole and textured spine jimping allow you to open the blade and position your thumb on the spine in slip-proof confidence ready for work. A Walker Linerlock (with jimped liner) and a 4-way pocket clip lets you set your carry and draw preference: Tip-up/tip-down left-hand/right-hand. Screw together construction.
Specifications:
Overall Length: 7.75"
Blade Length: 3.375"
Cutting Edge: 3.375"
Blade Thickness: 0.125"
Hole Diameter: 0.5"
Blade Steel: 8CR13MOV
Handle Material: G-10
Closed Length: 4.438"
Weight: 4 oz.
Information from Spyderco
LNIB
As shown
I have never used
$45
+$6 ship…..
PayPal to jdmtampa@mac.com
USPS MO / Check
Or contact me @ 813.220.1428
Jerry Moores
2.) Spyderco Sage Carbon Fiber Handle S30V (3" Satin Plain) C123CFP ***SOLD***
This model is in recognition of knifemaker Michael Walker’s contribution to the knife industry with his creation of the LinerLock® and ball bearing detent method of locking open a folding knife. While the knife is made in Taiwan, the flat-ground blade is produced with USA made CPM-S30V. It is paired with a twill-woven carbon fiber handle and LinerLock. Categorized as a mid-sized folder, the blade is flat-ground and PlainEdged. Designed for comfort and in-the-hand-ergonomics, the carbon fiber handle is vibrant with multi-colored fibers bonded together when manufacturing the carbon fiber. The weaving runs deep, making ridges and textures for the palm to adhere to while gripping and cutting. A silhouette wire pocket clip adjusts for left- or right-hand carry.
Specifications:
Length overall: 7 1/8"
Blade length: 3"
Blade steel: CPM S30V
Length closed: 4 3/16"
Cutting edge: 2 5/8"
Weight: 3.2oz
Hole diameter: 1/2"
Blade thickness: 1/8"
Handle material: Carbon Fiber
LNIB
As shown
I have never used
$100
+$6 ship….. ****SOLD***
USPS MO / Check
Jerry Moores
3.) Spyderco Tan Manix 2 CPM-M4, Model #C101GTNM4P2
***SPF***
The Manix 2 is one of the most popular in the Spyderco line-up since it was first released in 2010. This exclusive knife is a new Manix 2 with a Tan G-10 Handle and CPM-M4 Blade.
The Blade is Crucible CPM-M4 steel and is flat-ground with aggressive thumb serrations (jimping) and an oversized 14mm Spyderco Round Hole. Originally M4 made its name s a tool steel with high resistance to impact. Crucible's version incorporates their CPM-powdered metal manufacturing process with M4 creating a superfine, consistent steel-grain structure heightening its' already impressive impact resistance even more.
Locking the blade open is an ambidextrous and exceptionally strong lock called the Ball Bearing Lock which operates via a free-floating bearing encased in a high-tech polymer cage. It's spherical shape allows the lock to adjust across a large surface for solid and consistent lockup.
Inside the Tan G-10 Handle Scales are skeletonized dual steel liners increasing rigidity and strength without adding unneeded weight. The liners are scalloped, extending slightly beyond the handle scales creating textured jimping around a large portion of the handle's perimeter. A four-way pocket clip allows for left or right hand tip-up/tip-down carry.
Blade length is 3-3/8 inches for an overall length of 8 inches. This knife comes in the original box. This knife will make an excellent addition to your collection.
LNIB
As shown
I have never used
$175
+$6 ship…..
USPS MO / Check
Jerry Moores
Specifications:
Hole Diameter: 0.5"
Weight: 4 oz.
LNIB
As shown
I have never used
$45
+$6 ship…..
USPS MO / Check
Jerry Moores
Specifications:
Blade length: 3"
Weight: 3.2oz
Hole diameter: 1/2"
LNIB
As shown
I have never used
$100
USPS MO / Check
Jerry Moores
***SPF***
LNIB
As shown
I have never used
$175
+$6 ship…..
USPS MO / Check
Jerry Moores
