depends on several things: the steel, your use-pattern and preference of sharpness/angle.
steel: anything from ATS34/VG10 and upwards can easily be sharpened and and stay sharp at 30, or even 20-25 degrees
use-pattern: general light utility is suitable for a low angle edge. heavy duty chopping and prying calls for a more wide angle tp revent chipping/bending, etc...
preference: <fill in here>
if you use your Native 'normal' i suggest 20-30 degrees overall. (10-15 each side).
if you want shaving sharp: it comes when putting some work in it by stepping up to finer grits stones every time. also, it comes down to the 'touch' you have, or may have not. the 'fingerspitzengefuhl'. in English: when you're almost finished and want to get it really sharp, use only the slightest amount of force as if the blade is almost floating along the stone in zero-gravity, but still gently touching the stone's surface.
the easiest way way to get a rzor-edge is, as already mentioned by Meat, if to sharpen at really low angles.
good luck
denn
