- Aug 12, 2010
If I use diamond abrasives to properly grind a good relief edge, is the Spyderco Sharpmaker capable of re-sharpening as needed? Or would diamonds have to be used exclusively?
For manual sharpening by hand, there may not be much of a difference in terms of how well each works.Between diamond and CBN, which is better?
Whichever one is in stock when you need it.Between diamond and CBN, which is better?
One of my CBNs Sucks So Bad !For manual sharpening by hand, there may not be much of a difference in terms of how well each works.
CBN is heavily favored in industry for powered grinding applications, mainly because it's much more stable at high grinding temperatures. Diamond is known to break down at high temperatures, which ruins expensive diamond wheels and also contaminates the materials being ground.
Each are plenty hard enough to grind & refine the hardest of carbides in steel alloys. Diamond is the hardest of all at 7000 on the Knoop hardness scale, with CBN at around 4500 Knoop. Compare that to the hardest known carbides, which may be up to ~2800 Knoop or so.
I've long been curious about CBN but haven't tried any yet. I've been tempted to get either the diamond or CBN rods for my SM. I've got plenty of other diamond hones, most of them from DMT, so I don't necessarily need the diamond or CBN rods for my SM. But I've still been tempted to try them. My personal inclination is that I'd likely choose the diamond over CBN, simply because I'm more familiar with diamond hones.
That's what has me hesitating in trying new diamond or cbn hones. I've been spoiled on my DMTs, particularly in how relatively burr-free they leave my edges when finished with a light touch. I've tried other brands and none of the others have finished my edges so cleanly.One of my CBNs Sucks So Bad !
15,000 metal bonded . Every time I use it on a debured edge all it does is create a bur ! Does not improve the edge at all . Less roundy diamonds with a bit of bite would be nice in this one . . . at least .
They charged $111 PLUS SHIPPING ! Plus tax .
It might be a good BLANK to put some sharpening film on but that is about it .
PS : I didn't even want any thing remotely that fine . All I was trying to get was something I could put in my Edge Pro that was close to my Aligner Stone at 8,000 (without the dimple holes and longer) . l still just use the Aligner stone . The new ones are not as consistent grit quality as the decade old ones but it is dirt cheep at . . . wait for it . . .
$20 . Free shipping .![]()
