The Sharpmaker is in the basis setup with the medium and fine rods too fine. It won't be sufficient to sharpen a knife from dull to sharp. But those rods should be good to keep a blade sharp. As far as I remember you own a Double Stuff, too. The grit is the same. Difference is that the Sharpmaker will give you some aid to hold the angle. But apart that it won't be superior to the Double Stuff (in my opinion). You could buy diamond or CBN rods, but they are expensive. And I don't think that those extra rods could do what your DMT stones can't. Would be done twice.
Have you eveer thought about a sharpening system?
Personally, I wouldn't buy a sharpening system, too. I prefer freehand, too.I pause at the idea of using a sharpening system. For me, there is something missing in the experience of a sharpening system. I want to learn how to freehand sharpen.
Up until now, I have been using the DoubleStuff like a tiny bench stone, but I've been studying Michael Christy's sharpening technique, and I may try it his way.
You should give sharpening in hand a try.I got the Sharpmaker to see what all the hubbub was about. It appears that it is not going to do what I had thought it would do, but if I can use it to touch up edges, and take a working edge to shaving sharp, that would be nice. So far, that ain't happening.
about a year ago I got a pair of the 204 CBN Dimond rods, makes a big difference when sharping, much quicker then the regular stones that come with this kit, then I just use the brown stones to take out the small scratches then strop done, hope this helps.
I have been reading this discussion and agree with blanex1- The CBN or Diamond rods will allow you to reach a burr much quicker! Mister Coffee, you have done the research and bought the product. Out of the box, it's very slow. The CBN and/or diamond rods should make it work for you and end your frustration!
If you’re using the Sharpmaker correctly, it works. If it hasn’t worked for you so far, it’s not the equipment. It’s something you’re doing wrong.I may do that. But first I have to make sure that I'm doing everything correctly. My failure so far may be my fault and not the fault of the Sharpmaker. If I take a new knife to the Sharpmaker and can touch up the edge successfully, that will tell me that the knives I've been using up to now need to be re-bevelled before they go on the Sharpmaker. (I hope that makes sense.)
