The main difference between them is the Hinderer is taller from edge to spine. Length - they have the same blade length (3.5") and the Hinderer handle is maybe 3/16" longer. The Southard had about 1/4" more edge for the same blade, and the large choil on the Hinderer to me is just too large. Advantage Spyderco.
In a hard grip, the belly of the Hinderer has two areas where the thin edge of the scales bites into my fingers. One is at my pinky finger, and the other is at the index finger in the finger pocket. The finger pocket on the Hinderer is also a touch cramped because of the way the flipper tab curls back so much. It's more neutral on the Spydie. I always thought the Southard handle would not be tall enough, but it is. I also like that the show scale on the Southard is cut back at the lockbar access. I am almost convinced I am going to cut some relief (just a very small amount) on my Hinderer, which will give better lockbar access, and maybe relieve some of the bite on my index finger in a hard grip. Advantage Spyderco.
The Southard is CTS 204P steel. I believe this is a premium steel, but I have zero experience with it. Hinderer is CPM 20CV and I really like this steel. Advantage Hinderer only because of experience with one and none with the other.
The Southard is a thinner blade, hollow grind. I am sure both can be made to be very sharp. Both of mine are wearing factory edges at the moment, but I have a hunch the Southard blade geometry is a performer, whereas the Hinderer is a bit of a brute here (a known feature). Advantage Spyderco, I think.
Flipping action, lockup and centering on both are perfect. I made an "armorers tool" and a flat screw driver out of 1964 Nickles (coin silver, softer metal), so I can adjust the pivot on the Hinderer. I got both blades flipping nicely and both are dead center. The flipper tab on the Hinderer is sharp at the point. The Spydie is slightly rounded. They have the same flipping action but I like the tab on the Southard. Advantage Spyderco.
Pocket clip on these both are nice, but my Southard came with the deep clip installed. I am not going to put the stock clip on it. I like them both and don't have any preference here. Neutral.
Cost - I bought these both on the secondary market at about a 3 to 1 price difference. Advantage Southard, by a large margin!
Oh, one more thing. The scale cutout on the Spydie puts your thumb right where it needs to be to disengage the lock. On the Hinderer my thumb slipped once when I was closing the knife and the blade clacked down on top of my knuckle and bit me pretty good. I need to be careful. Not a fault of the Hinderer design, I just need to pay attention. But the Southard cutout just seems smarter to me.
More importantly, why are there scale screws on the lock side of the XM instead of nuts?
That is not typical of Gen6 XM Hinderers, at all. Usually it’s lock side nuts passing through stand-offs with show-side scale screws.
Definitely the most interesting thing in this thread, for me anyway. It’s the little things.
Is the Hinderer brand new from a distributor, or second hand?
This was actually my knife that I traded to him. I bought it new from Bladehq.Is the Hinderer brand new from a distributor, or second hand?
And I do have to admit that the Southard is quite a knife. Its hard to believe the Hinderer is twice the money . It must be just because of the name more than anything else. Plus Hinderer is more in the realm of semi-custom right?
