- Dec 19, 2002
Spyderco Dyad 44GPSGY, VG-10 Steel, G-10 Handle, PlainEdge & SpyderEdge, Sprint Run
Suggested Retail: $279.95 Our Price: $159.95 You Save: $120.00
Limit 1 per customer
http://www.knifeworks.com/spyderco.aspx
The Dyad revolutionized the concept of traditional twin-blade pocketknife by adding the advantages of on handed opening, convenient clip carry, reliable patented by-pass lock mechanism, and both the cutting power of a serrated edge and finesse of a plain edge. This pocket powerhouse is back in limited quantities as a Sprint Run, featuring textured gray G-10 scales and an all-new four position hourglass clip. its VG-10 stainless steel blades include a SpyderEdge sheepfoot profile and a full-flat ground plain edge clip-point, giving you the power and versatility to tackle virtually any cutting chore.
Specifications
Overall Length: 8.43in., 214mm.
Closed Length: 4.65in., 118mm.
Blade Length: 3.78in., 96mm./3.35in., 85mm.
Cutting Edge: 3.39in., 86mm./2.76in., 70mm.
Blade Thickness: 0.098in., 2.5mm.
Blade Steel: VG-10
Handle Material: G-10
Weight: 5.8oz., 164g.
Grind: Hollow/Full-flat
Country of Origin: Japan
