- Dec 19, 2002
Spyderco Squeak Slipit Sprint Run, 154TIP, ELMAX Blade Steel, Titanium Handles, Pre- Order
Suggested Retail: $279.95 Our Price: $163.95 You Save: $116.00
http://www.knifeworks.com/spydercos...axbladesteeltitaniumhandles.aspx#.Va-Ge8LJDIU
Spyderco Squeak Slipit Sprint Run, 154TIP, ELMAX Blade Steel, Titanium Handles Produced in Maniago, the Squeak SLIPIT is a Spyderco non-locking one-hand open, clip carry folder called a SLIPIT.
It's designed for legally-restricted carry in locales where locking folders are prohibited. The blade is ground full-flat and made from Austrian Bohler-Uddeholms Elmax steel. Elmax boasts high carbon and chromium contents and an extra-fine grain structure that provide extreme edge holding and corrosion resistance. Textured jimping is machined from the blades spine and choil for increased slip resistance. The Squeaks blade is held in the open position when cutting by a notched-joint at the knifes pivot. When closing the blade, the notch generates resistance functionally similar to traditional slip-joint penknife and performs the additional function of smoothing the motion of the blade opening. Increasing control and comfort Spyderco designers add a deep finger choil, naturally jogging the index finger into a position on the underside of the blade directly below the thumb. Positioning the index finger in this choil blocks the blade from accidental closing when cutting and provides a grip position that allows the user to choke-up closer to the cutting edge for greater dexterity. The handle on this Sprint Run model is made from matte finished Titanium and it gives this knife a much more durable feeling in the hand than the FRN model. For a knife this small, you feel like you have a sturdy blade and don't have to deal with any locks. Just push the blade closed and clip it back in your pocket. Knives like this might just make you appreciate a blade that does not lock.
Specifications
Blade Length: 2.00"
Cutting Edge: 1.75"
Blade Thickness: 0.118"
Overall Length: 5.05"
Closed Length: 3.05"
Blade Steel: Elmax
Handle Material: Titanium
Weight: 2.6 oz.
Opener: Thumb Hole
Made in Italy
**Limit one per Customer**
Specifications
Blade Length: 2.00"
Cutting Edge: 1.75"
Blade Steel: Elmax
Weight: 2.6 oz.
Opener: Thumb Hole
Made in Italy
