- Dec 19, 2002
Spyderco 10FPGYE Endura4 Super Blue, PlaindEdge, Sprint Run Our Price: $81.95
http://www.knifeworks.com/spyderco10fpgyeendura4superblueplaindedgesprintrun.aspx
Limited to 1 per customer
The destinies of Spyderco Delica and Endura have always been intertwined and with good reason. Like its smaller counterpart, the defining characteristic of this extraordinary version of the Endura4 is its full-flat ground blade with an Aogami Super Blue core stainless steel outer layers. It is housed in a gray fiberglass-reinforced-nylon handle with skeletonized stainless steel liners, a reliable back lock mechanism, and a versatile four position pocket clip. Produced in limited numbers, this unique expression of the Endura is an uncommon blend of superior cutting performance and a comfortable, familiar format.
Specifications
Overall Length: 8.78in., 223mm.
Closed Length: 4.98in., 126mm.
Blade Length: 3.80in., 97mm.
Cutting Edge: 3.44in., 87mm.
Blade Thickness: 0.11in., 3.0mm.
Blade Steel: Aogami Super Blue
Handle Material: Gray FRN
Weight: 3.40oz., 96g.
Grind: Full-flat
Country of Origin: Japan
Spyderco 11FPGYE Delica4 Super Blue, PlaindEdge, Sprint Run $74.95
http://www.knifeworks.com/spyderco110fpgyedelica4superblueplaindedgesprintrun.aspx
Limit 1 per customer
These will be shipping on Tuesday 11/12/13
C11FPGYE Delica4 Super Blue Sprint $74.95
Experience the ultimate in cutting performance from the Delica4 design with this limited-edition Sprint run featuring Aogami Super Blue blade steel. Manufactured by Hitachi Metals Ltd., one of the premier steel manufacturers in Japan, Aogami Super Blue combines the same high quality iron sand used in legendary Japanese swords with high-tech alloys to create a steel capable of extreme sharpness and edge retention. The Delica4 Super Blue takes an ordinary gray-handled lightweight Delica and supercharges it with a laminated blade consisting of a Super Blue core sandwiched between layers of 420J1 stainless. Full flat ground for exceptional edge geometry, this extraordinary blade is mated to a lightweight handle featuring skeletonized stainless steel liners, injection-molded fiberglass-reinforced-nylon scales, and a four-position clip. Like all lightweight Delicas, this extraordinary knife offers versatile tip-up or tip-down left and right-side carry and completely ambidextrous operation by virtue of its Trademark Round Hole and sturdy back lock mechanism. Sure to be one of the most prized Delica variants ever produced, this unique knife pushes the envelope of pocketknife performance.
Note: Aogami Super Blue is a high-performance, high-carbon steel and is not stainless. It requires proper and diligent maintenance to keep it corrosion-free. Spyderco is not responsible for the corrosion or pitting of a high-carbon blade.
length overall 7.15" (182 mm) blade length 2.90" (74 mm) blade steel Laminated Super Blue / 420J1
length closed 4.25" (108 mm) cutting edge 2.56" (65 mm) weight 2.4 oz (68 g)
blade thickness 0.098" (2.5 mm) handle material FRN
Specifications
Grind: Full-flat
