- Dec 15, 2008
Laci Szabo is a law enforcement officer, a veteran U.S. Marine, and a world-class martial artist. He is also one of the most visionary knife designers in the industry, combining a unique flair for aesthetics with an in-depth understanding of function and defensive application.
The heart of Spydercos Szabo folder is its 4.60-inch CPM S30V scimitar-shaped blade. Its partial hollow grind creates excellent edge geometry while reinforcing the spine for increased strength. A Trademark Round Hole in the blade supports swift one-handed opening with either hand and, together with a subtle guard on the edge side of the blade, effectively protects the users hand during use. An unsharpened swedge on the back of the blade ensures an acute point and flows smoothly into a scalloped area on the spine that enhances the blades trapping potential when applied with reverse-grip skills.
The Szabos generously sized handle is constructed of full stainless steel liners capped by Gold Line carbon fiber/G-10 laminate scales. This striking material consists of an outer layer of carbon fiber embedded with gold-colored wire that is laminated to a G-10 base layer. Visually stunning yet incredibly durable, it provides a secure, non-slip grip.
To cope with the extreme leverages associated with its longer blade, the Sazabo folder features Spydercos high-stength Compression Lock accompanied by an internal self-close mechanism. Nested within one of the handle halves, this mechanism uses a spring piston to engage a plate attached to the blade tang. When the blade is closed, the piston gains mechanical leverage to rotate the plate, keeping the blade nestled securely in the handle for safe carriage. A four-position clip supports tip-up or tip-down carry on either side of the body.
Knife was purchased and never used. Do not have the box just so you know. These were MSRP of $299 and they are now discontinued.
Very impressive knife. SOLD
View attachment 634007View attachment 634006View attachment 634005View attachment 634008
