Spyderco Temperance Passaround #2
Well, here’s my thoughts on the Spyderco Temperance that I received as part of the passaround.
The blade features a nice flat grind of VG-10, one of my favorites. As soon as I unsheathed it, I was immediately reminded of the C54 Calypso. The blade shape is basically the same, though this is wider and has a bit more belly to it. It came to me somewhat sharp, but in short order it was literally shaving sharp. I mean literally as I later shaved about ½ of my face with it. It’s something that amazes me. VG-10 sharpens so easily to an extremely fine edge, yet it holds it for a LONG time. The edge has a continuous curve that slices very well. Not much else to say here, it just works.
The handle is a very nice polymer molding on which the mold lines are very faint. It is very hard and a little slick, but the shape helps to keep it in the hand. Here is one of two things to improve in my mind. The butt of the knife features a nice, wide and very comfortable thumb shelf that is used to “cap” the butt with the thumb in reverse grip. I don’t generally do that, so I found the butt to be too wide and to get in the way during shifts between front and reverse grip. I would prefer a slightly narrower butt section or maybe even cutting off the handle just forward of the lanyard loop. This way it would be a lot smaller and easier to conceal and the thumb would “cap” the butt in a more natural fashion. However, these are personal preferences and not a knock on the design. I’d also like to see the texturing that is molded into the handle done a little more aggressive.
The sheath is a nice sandwich style kydex job with a Tek-lok for attachment. This was my first time to really handle or use a Tek-lok and I’m quite impressed with the system. I can recommend it for anyone who wears a knife, gun, or whatever else on their belt and doesn’t have to conceal said item. For concealment, it positions the knife away from the body a bit too much for me. I wore it for 2 days using the Tek-lok and couldn’t conceal it well under a T-shirt. Today, I attached an adjustable belt loop and carried it IWB. That’s normally how I carry a knife like this and it worked much better for me personally. It concealed easily under a T-shirt and was very comfortable. Now for my other slight gripe against the system. While the sheath is good, it could be better. I understand that it’s not easy to mass produce a really good kydex sheath, so I don’t think they did bad. I would rather see a slight change. While the blade is held secure enough that I couldn’t shake the knife out, it comes out a little easier than I’d like. I like to be able to sleep with a knife like this. That requires a sheath that holds securely. What I’ve found to work best for this level of security while allowing a fairly easy draw is for the kydex to be molded into the finger groove on the knife. However, this sheath engages the sides of the handle and leaves the finger groove completely uncovered. This is great for a good hold before you draw as nothing prevents a full grip. But to do that, security in the sheath is compromised. Once again, I don’t mean to say that it’s a bad sheath, it’s excellent. I can see why it was made that way. I just prefer mine in a different style. To each his own.
Overall, it impressed me enough to make me want to buy one immediately. No knife has ever done that before. I took it out of the package and within 1 minute decided that I am going to buy one. No knife has ever pulled that off before. I generally look a knife over about 10 times before I decide I like it enough to buy. This was instant love.
When I get mine, I’ll make my own sheath for it and slim the butt or cut it off. That way it’ll make a great companion to it’s little brother, my Lil’ Temperance folder and my Gunting. Those two modifications will make it perfect for me. I can easily recommend it. Whether you look for a knife for utility, self defense, hunting or what ever else, this should serve you well.
Dave recieved the knife over the weekend, (had an auto accident also, everything/one is fine, except the car:( )
Will ship the knife to the next person on the list tommorow, and post a review later.
Thanks again.
Hey guys the postperson just left the passaround knife in my mail box with a note indicating that the address and the zip don't match, apparently I transposed the last couple of #s.
Sorry, I mailed it out from work this afternoon, so Steve, you should have it in a day or two,(I should have delivered it myself, it would have gotten to you sooner).
Here is my review. I have to say that when I first recieved this knife, I initially didn't like it. I thought that it was ugly and that the edge of the knife was not in the correct place in relation to the handle. Last night I decided to give this knife some tests. I started on some cardboard. I did some cutting, stabbing and slashing and was very impressed. The VG10 blade perfomed very well. Making nice clean cuts was effortless with this knife. I was able to cut free hanging paper with ease. After multiple cuts of cardboard and paper the temperance was still hair popping sharp. I really like the handle of this knife. It is comfortable and secure no matter how I hold it. I think that the sheath is excellent. I really like the fact that I can get a full purchase on the handle while the knife is still sheathed, and of course the teklok is great, although I would not ever wear this knife inverted because I don't feel that the sheath is secure enough for this method of carry. It is obvious to me the amount of thought that was put into the temperance design.To sum up my review, after a few simple tests with this knife my opinion completely changed. This knife is now on the top of my list for future purchases.
