Spyderco Watu & Franken Para 3 LW
Feedback: +21 / =0 / -0
Spyderco Watu - $200
Nudies:
At least the second owner, unsure past that. Weird/Unique is probably the best way to describe the Watu. Will come with the OEM carbon fiber scales as well as the Karbadize scales; however, it is important to note that the Karbadize set does cause the stop pin to have a 'rattle' sound until the blade is engaged; it does not do this with the OEM scales. (It doesn't affect the blade or lockup at all, just wanted to be transparent about it) Has a couple of snails on the blade and a sharpening choil mod. Will come in a padded Civivi pouch.
Franken Para 3 LW - $120
Nudies:
Started life as a SNK 4V and I did a blade swap from an S110V frame that I had - so you now have an S110V blade in a 4V FRN handle. Has a few small surface scratches, sharpening choil mod and has been sharpened. Favors the clip side, as most of the FRN models do. Will come in the OEM 4V box with SNK sock.
