- Dec 19, 2002
Spyderco Worker SPRINT RUN & Spyderco Serge Panchenko Dog Tag Folder
Spyderco Worker SPRINT RUN Folder C01GPGR, VG-10 Steel, Green G-10 Handle
Suggested Retail: $279.95 Our Price: $169.95 You Save: $110.00
http://www.knifeworks.com/spydercow...grvg-10steelgreeng-10handle.aspx#.VAiufRsg_IW
Several times per year, Spyderco manufactures a limited number of knives not found in their regular product line. These batches are known as Sprint Runs. The runs are limited in number and will not be reordered or available again once sold out. This special model revisits Spyderco’s first model, the Worker, now with a VG-10 blade and Green G10 handle.
True to its name, the Worker model delivers exceptional quality to meet a variety of everyday needs. The distinctive modified clip-point blade has an extremely fine tip for intricate slicing and trimming. When the knife is opened only slightly, the sharpened false edge can be used to cut items such as string or tape. The hole promotes convenient opening with one hand, and the lockback mechanism is situated higher on the G10 handle to facilitate easy one-hand closing. A great classic style with a very low profile, the original CLIPIT, reintroduced, continues to serve as a functional pocket tool. 1500 piece Sprint Run.
Specifications:
Blade Length: 2.6"
Cutting Edge: 2.5"
Length Overall: 6.5"
Length Closed: 4"
Blade Steel: VG-10
Handle Material: Green G10
Weight: 2 oz.
Made in Japan
Spyderco Serge Panchenko Dog Tag Folder C188ALTIP
Suggested Retail: $119.95 Our Price: $69.95 You Save: $50.00
http://www.knifeworks.com/spydercodogtag.aspx#.VAjMnxsg_IU
Based on one of Serge Panchenko’s most popular custom designs, the Dog Tag Folder is a unique departure from Spyderco’s typical folding knife construction methods. Its single-sided handle is fabricated from solid titanium and accurately replicates the size and shape of a military dog tag. Features a green anodized handle scale and contrasting blue anodizing on the back strap and pivot pin disk. The center of the handle scale is machined to create an integral spring bar that houses a steel ball bearing for the blade’s detent mechanism. At the top of the handle is a titanium back strap that defines the blade’s limits of travel in both the open and closed positions and provides protection from the edge when the knife is closed.
The sheepfoot-style blade made from premium CPM® S30V® particle metallurgy stainless steel with a stonewashed finish. To protect the edge when closed, the blade is chisel ground with a single flat bevel on the front side.
A non-locking folder, the Dog Tag’s blade is held in place in the open position by a detent mechanism. A ball bearing in the handle scale’s integral spring arm indexes holes in the tang of the blade to hold it both closed and open. Since the blade does not lock, care should be taken during use to apply cutting pressure only in a direction that maintains the knife’s open position.
Specifications:
Overall Length: 3.23" (82 mm)
Blade Length : 1.23" (31 mm)
Blade Thickness: 0.118" (3.0 mm)
Closed Length: 2" (51 mm)
Cutting Edge: 1.14" (29 mm)
Blade Steel: CPM S30V
Handle Material: Titanium
Weight: 1.0 oz (28 g)
Country of Origin: Taiwan
Specifications:
Blade Length: 2.6"
Cutting Edge: 2.5"
Length Closed: 4"
Blade Steel: VG-10
Weight: 2 oz.
Made in Japan
Specifications:
