Spyderench, EDC as a mechanic, after a month
my rating of 7.5/10
this thing is great! i work much more efficiently everyday, not having to run to my toolbox for the simplest of tools. its very much everything one can fit in such a small package. between this and my streamlight keymate, i have been doing a lot more street repairs as well.
knife, pliers, wrench, screwdrivers, and a file. it has a Spyderco blade, so you know is sharp and durable, Aus8. the pliers have dual adjustments, they are definately solid, but not having a even jaw really hurts the tool. the wrench is good enough for a 13mm bolt, and you can stretch it for a 14mm. this is obviously the best part of the whole tool. well, the little phillips/file/poker, the file is good, but the little phillips screwdriver should have been a mini one, a precision glasses sized one. the screwdriver bits are fine, but anyone who ever used a screwdriver knows that you need reach for just about any screw. i need a bit extension!
now, to make a 10/10 mechanic tool.
besides the aformentioned; an even plier jaw, mini philips screwdriver, a screwdriver bit extension... the blade should be flush on the blade handle and double as a cutter/wire stripper because it is that easy to make it one. there should be a part of the tool that sticks out and can be used as a pry tool, i really hate to use the blade to pry. and lastly, the whole thing needs to lock together a bit tighter!
well, despite all my whining, and being far from a 10/10 item, it is still the best multi tool i've ever had because it just suits a mechanic so well.
They are nice:) I've got a ByrdRench and it's quite the handy tool. I never realized that an adjustable wrench would come in so handy until I started packing one around:D
For years, my EDC kit consisted of a Super Tool, MiniMag flashlight and thin 6" adjustable wrench, all in a belt carried Nite Ize pouch. Why not just add a small adjustable wrench to what you already have? It's a whole lot cheaper than either a Spyder/ByrdWrench, or am I missing the point? ;)
You're missing the point, I dont need another 6" in my pocket, that would just be too much. :rolleyes:
Well my point is that I would never be the kind of guy that would say, "Yep, today I'm going to need an adjustable wrench." If I needed something to hold a bolt, I would just get a pair of pliers and "make due".
Would a standard wrench be cheaper and more effective? Absolutely:D However, my multi-tool sickness does not take this into account. I could get by with just a plain ol' Leatherman....but I have a drawer full of tools for "specialized uses":D
In a pocket, not so good, but in a belt pouch, a small wrench goes all but unnoticed.
Without knowing what kind of mechanical work you do, my own situation may not apply, but decades ago I worked two different stints as a mechanic. In the army, I maintained wheel and track vehicles in both shop and field environments. Later, I had a job at a NASA installation doing setup and takedown of test apparatus. In neither situation did I carry or use a multitool. Of course, this was in an era BL (before Leatherman), but thinking back, I don't know how useful one would have been, since I always had access to proper tools and equipment, all superior to any pocketable widget.
Now that I am now longer practicing the trade, a multitool makes sense as an everyday "just in case" item, and as such, I use mine every day (before breakfast this AM, in fact :) ). But it is hard for me to think of it as very useful for mechanical chores.
Since most mechanical work I do these days is simple maintenance or emergency repairs on my car, I usually have a tool kit in the trunk. That said, I have made some quickie road repairs with my Leatherman because under the particular circumstances, it was more convenient, such as a few seconds outdoor exposure during a driving rain while turning down a loose nut on a windshield wiper vs. a long time offloading luggage to get at my tools in the trunk (this happened twice.)
Now, if you just plain like multitools, then any reasonable excuse to get a new one is just fine. I've done it myself. :D
