I use sandpaper anyway, why would I pay someone to convex a knife that I can convex myself? I don't want a convex grind. At this point I just want to take the current flat microbevel down from about a 30 degree angle to 15 degrees. In the future depending on use, wear and maintenance I may convert the saber grind to a scandinavian grind by buffing out the microbevel, that is, if I can find sharpening implements that can efficiently maintain this steel... Tried applying pressure, tried using honing oil, all I've managed to do is remove less than a millimeter of the blade finish along the edge. Real consistant, but again, not seeing any sort of material removal. I haven't attempted a bastard file-I think it would probably just destroy my 11 dollar nicholson, and I don't want to use anything that rough on this brand new blade anyway. I REALLY don't want to have to spent 50-60 bucks on a set of daimond sharpeners specifically for this knife.... noone knows exactly what Rockwell hardness this steel is? I use knives WAY too much to spend so much time sharpening them in between uses... as much as I love this knife, it may not work.
