- Jan 3, 2011
Im working on my third knife now and I would like to attempt to pin the 416 SS bolster with 3/16 416 SS pins. I tried to order a straight flute ream some months ago but they were all sold out. Now its crunch time and id rather not order one unless I have too. Mostly because every place wants three times the cost of the tool in shipping costs. Ive spent quite a few hours reading about pins and peening. The basic principles make sense... The translation from American to Canadian doesnt. Ive looked at about a dozen drill conversion charts and none of them match what im seeing so...
Drill bits- When I put 3/16 pins in micarta handles I drill with a 3/16 bit but I keep reading that you cant do that because 3/16 isnt really 3/16. Supposedly I should be using a #10 or #12 ok but those dont match any drill bits in any hardware store except 3/16 which is closest. Idk... (Beating me head on the keyboard)
The general process is drill, taper the hole and countersink the first 3/16 or so. This I cant even...
A standard countersink like you use for screws ? Or are people referring to the taper as a countersink ? And if its a countersink bit I cant find any info on the size I need.
Ive also heard I can make a tapered ream using a drill bit then taper it. It just wont remove any material from the hole. I should be able to taper a bit just fine but again... What size bit should I be tapering ?
So im trying to make the pins virtually invisible. What is the theory behind the tapering and countersinking to make it invisible ? Can it be done without a proper factory ream ?
One last thing. Ive never actually seen the process of peening a pin. Does anybody know a good youtube vid that demonstrates the process. Especially the hammering of the pin and how to mushroom it ?
Thanks again all !
Thanks again all !
