- Aug 28, 2009
earlier I had some questions about finishing stabilized wood, and they were answered quite well and I was satisfied with the results, that is until early this morning when I had decided that the handle was good enough. I disassembled the knife to make sure that the tang and everything was dry. Things were snug but I could push the pin out with little pressure. I cleaned and oiled the tang and started to reassemble the knife and when I went to slide the temporary pin back in, the handle split at the pin hole. I was under the impression that stabilized wood was tougher then non stabilized wood
So here is the big question, is stabilized wood more delicate then non stabilized wood until every thing is buttoned down? If so how do you pin this stuff?
My pin was undersized so that I could take it out and put it back in to test fit as I went on the finishing. I don't peen my pins I just drill my holes a couple thou under my pin size, press them in with glue. Knowing that i would be taking this one apart a number of times while finishing it I stuck some pin material in a drill and sanded it till it was 1000th under my hole size and chamfered the ends, so I know that isn't what cracked it. It is almost as if there was an unseen flaw in the grain that I happened to drill through and the last time I slide the pin through was the final stress it could take. I am glad it didn't break while in use, but after 50 bucks and 2 days of making the tang hole, shaping, and finishing (all done with files and sandpaper) I am wondering if it was worth the extra money for the fancy color and hard finish.
Any how pipe in and give your opinions, I am taking today off from making and will start cutting up a piece of non stabilized wood tomorrow to make a new handle, it just wont look as good.
