- Dec 27, 2013
I see quite a bit of misunderstanding whenever the difference between home stabilized and professional stabilized wood comes up.
I've had about 3500 pounds of wood stabilized by K&G, I've talked to brad about his process at great length, I have my B.S in chemistry, and my exit thesis was about wood stabilizing and adhesives.
3 things set professional and home stabilizing apart.
Equipment, materials and expertise.
Equipment: people always talk about the importance of a low vacuum or of long soak times as explanations for why their home stabilizing set ups are just as good as K&G. The issue is, vacuum is a diminishing return. The benefits of lower vacuum become exponentially less intense as the pressure lowers. That is where k&g is diffrent them any home set up. They use a pressure cycle. The do a pressure cycle followed by a vacuum cycle to get excellent penetration of resin.
Materials: K&G's resin and cactus juice are the chemical. Kind of... the resin being used is Methyl methacrate. It's basically the monomer that makes up acrylic. But the grade of the chemical used varies. Cactus juice is a relatively low grade. It contains a variety of side products, partially pulverized monomer, and other byproducts that lower the penetration and curing potential ofnthe resin. K&G use a much higher grade, and it is EXPENSIVE. That's just a fact. It's expensive stuff. Good chemicals are.
Expertise: brad had been doing this a LONG time. He knows what he is doing, knows how to tweak his processes, they check the moisture level of.each and every block.
The results: K&G stabilized wood is better than home stabilized wood. I know someone will comment that I havnt tried THEIR stabilized wood and I dont know. I have handled thousands and thousands of pounds of stabilized wood. I've also handled lots of wood stabilized in home set ups. And I can instantly tell the difference. The weight alone is a give away, in medium weight woods like hard maple, mango or tamarind K&G wood is generally 20-30% denser. There is also the matter of consistancy. In those thousands of pounds of wood, I have had maybe 10 blocks with sticky patches inside of uncured resin. My shopmate has a failure rate of roughly 1 in 10 from blocks purchased from home stabilizing.
Can home stabilizing work? Yes definitely.
Are home stabilized woods often good enough for use on a knife? Yes definitely.
Are they on par with K&G? No. Full stop.
