Yes
how many do you have? Try 2 and then 3 together
I think the biggest problem would be heat. When it heats up the glue will lose it's grip. If you manage to keep them cold it might work , but when I profile I use old belts and they heat up alot. Maybe You can drill the pin holes and fix them with bolts.
This has been mentioned, but I'll ask why not just use a couple of small vice-grip welder's c-clamps? These give you something to hold onto and not worry about heat build up, and when you are finished with one side, you just switch the clamps to the other side one at a time to maintain their orientation. Then you don't have to break them apart if the glue does hold and don't have to spend $ on glue or suddenly run out of glue.Could I stack couple of them on each other with a drop of CA glue and then profile them? While at it would it work for drilling the holes as well?
I do most of my profiling against a table so clamps would be in the way.
Honestly, all in all, would this glue and stack or clamping save any significant amout of time?
If the homework is done on the bandsaw there is so little left to take of with the grinder. It is super fast.
For identical profiles, I can see the point though
What grinder do you have coming? Curious since we are both in Europe
Since we are going off topicWhat grinder do you have coming? Curious since we are both in Europe
Price looks good. Is the VFD ip65?
I looked at them, Claryx, Batkovic (Croatian) and G20 (Slovenian) as well. The nice ones were out of my price range.Since we are going off topic
My new lions process grinder should come next week.
