- Feb 5, 2010
I'm trying to learn a new technique... how to make stacked handles.
After reviewing the knives made and sold by the Swedish makers that I've been buying blades from, I discovered that they favor this technique, and I want the knife I'm working on now to be as nice (and authentic) as I can make it.
For those who are unfamiliar with the concept, check out this representative sample of bolsters and handles using this method.
You'll notice that the bolsters are often made with something other than metal. This was one of the things that attracted me to this approach. You might also notice that the individual elements in the stack are separated by spacers, either metal or the usual plastic spacer material. The elements involved seem to generally include ivory, bone and wood of various types. These are the same elements I am attempting to combine.
I can wrap my head around the design principles pretty well, but where I'm getting stalled is in the assembly techniques. I think I've worked out an approach. The simplest would seem to be to glue the elements together in a mostly-complete shape and then do final sanding and finishing after mounting the assembled stack to the tang. One concern I have about this approach would be the strength of the assembled stack.
Putting my head into the problem of strengthening the stack, I came to the thought that welding a bolt to the end of the tang would allow me to mount the handle with a screw down butt piece, possibly hiding the nut in a piece of ivory. This is what brought me to the point of feeling compelled to obtain welding equipment and learning the skills. So I spent some time studying welding and have come to the point where I believe I'm ready to attempt welding a bold to the end of a file (for practice). I'll probably do that this weekend. If that goes well I will have the confidence to do it on the knife, once I make the final determination that it is needed.
Which brings me to the point of this post. I'm looking for your opinions. Am I overcomplicating this process? Do I really need to be able to screw down the assembled stack to give is structural integrity? Or will the epoxy alone be adequate to hold the handle together?
One other thought I had was to embed guide pins along the length of the stack, both to align the pieces and to keep them from twisting off during final finish. Is that really useful or necessary? My though was that at the very least such holes might provide an additional channel for the epoxy to run through to create a stronger bond.
Am I overthinking this? Or am I missing something important?
Any guidance or suggestions would be welcomed.
- Greg
- Greg
