Nice post, Will! Thar's simular to the way I do my leather washer handles. I consider it paramount that you soak heavy weight veg tanned leather washers and compress them. I cut square washers and also cut the tang holes in them first. I use at least a 3/8" bolt and large steel washers. After soaking the washers in warm water, I stack them and then run them on the long bolt. I place a steel washer ahead of the first leather washer, and after the last one, and then the nut. Then, tighten down the nut. You don't want to crush the leather washers, but compress the dickens out of them. The leather will compress quite a bit, so you will have to allow for this by some ready to add washers, so your stack will be long enough. Let dry, and then seperate, KEEPING THEM IN THE EXACT SAME ORDER THAT THEY CAME OFF THE BOLT. The thing is, there will be some variations in the washers, and they will actually lock together when you assemble the dried washers on the tang. I use an oversized tang hole in the washers, for a reason. I use good contact cement on the contact faces of the leather washers, letting it dry properly. I then take a fresh mixed batch of Brownell's Acra Glas (gel) and slather the tang. Leave about a 1/4" of the area close to the tang holes on the faces of the leather washers VOID of contact cement. Keep that area clean, and apply the 'glas to each washer, on the void of contact cement part that is a clean ring around the tang hole. When you assemble the handle, have your knife point pointed down, in a vise. As you add the washers, fill in the void around the tang with the 'glas, and also apply some to the small clean ring around the tang hole of the leather washers. Stack, glue and fill, stack, glue, stack, glue. etc. Keep filling the void around the hole with the 'glas. This will end up being a great anchor for the washers and the whole handle. You press the washers together while you assemble them on the handle, and the contact cement will help lock them in place. Each washer is custom fit to the next one because of the wet/dry/compress proceedure when you wet formed the washers.You can then easily grind the handle on a good belt when the handle is dry. One word of caution, the belt will quickly eat the leather much faster than you would think! Go E-A-S-Y on grinding the handle. I finish my handles with a good leather balm. Actually, the leather washer handles are easy to make. The reason I use square washers on the tang? It gives me a good reference when I grind the handle round. It's easier for me to end up with a uniform round handle when I start grinding with a square shape.
