Has anyone tried fuming a handle with ammonia? I've seen in done on wooden longbows with great results. It gives the wood an aged look after a few days of fuming. It soaks into the wood so it won't rub off on your hands. I haven't tried it yet but I plan to. Here are some pictures of a bow being fumed.
Photos of a 5 day fuming procedure:
day 4
That darker handle is just beautiful , if you made it then you are awesome.
Either way I love that handle.
Ditto on Hickory n steel's comment. That has a nice warmth and richness to it that makes you instinctively want to put your hands on it.
How do you accomplish that finish?
thanks,
Bob
I think I could do that. Although I suppose I'd have to eat the ribs. I was brought up with a very strong habit to never waste food. Left home 50 years ago and never could seem to break the habit. Oh well, I guess some things require sacrifice.
Thanks for sharing quinton. I was half expecting the answer: "I can tell you, but then I'd have to kill you".
Bob
I don't know if this has any application to an axe handle, but quinton's smokehouse experience got me to thinking about this method used for shillelaghs.
"The wood would be smeared with butter or lard, and placed up a chimney to cure, giving the shillelagh its typical black shiny appearance."
Bob
When I cold smoke my bacon and jowls in the spring, I discovered that the axe I used to split the wood started taking on that rich color because I kept it in the smokehouse. Now, don't tell anyone or...
You slaughter hogs in the Spring not the Fall?
Older handles...
Sorry if I'm hijacking this thread...
Very interested in trying to semi-duplicate a color like this. I have an old 5# Legitimus that I restored (had a badly cracked/damaged head). I measured and have marked the original haft (every inch I took length, width and radius measurements at front/back + middle of width) so I can duplicate the pattern to a very similar grained, hand-picked HH haft. Only problem is the HH haft is brand new and doesn't have 40-50 years worth of use and annual BLO maintenance under its belt. How fast does a BLO'd haft darken vs. using stain? I'd rather not use stain but when I give this axe back I want it to look like it did when it was given to me. I went so far as to have the axe head powder-coated the same color red as it was originally from Collins so that with a little use it should wear similarly (except for the hammer marks on the butt). My hopes are that the metal (and newly added welded in metal) will patina same as before. I also hope her father says "just keep it, if I need it I know where to find it"...
Is it possible to stain to match a similar color to this or should I not mess around with that and just BLO & use it?? Thx.
