- Jan 9, 2011
Let's talk stainless Damascus steel! I want to make my own billets for my folder blades and maybe more.
This Spring I am going to set up my Smithy permanently and want to get into making Damascus. I am probably going to start with 15n20/1084 until I get a good feel for everything then want to move to stainless. I've done loads of research for the last few years and have a bit of experience (but not much) with the forge as I still need a better anvil and permanent spot for everything. I lack on forging experience but am determined to make everything work. I think I know the answers to my questions from my research but would like to hear what you guys think!
1. Will the Uncle Al's 24 ton press do a good job with stainless damascus? I have heard it is a lot harder to work with than high carbon. I've also seen really nice stainless billets made with this press. I've seen a really cool portable 16 ton press that looks good too... know something like 50 tons would be best. I do not want to build a press. Any thoughts on other presses will be much appreciated!
2. Can I get away without a good anvil for a short while when I get started? I have my RR track and can do some very light straightening on some I-beam I have... but am well aware of the limitations of my current setup. I think I'll be good hand straightening folder sized stainless billets on the rr track or most likely in the press alone? What about straightening larger high carbon billets? I'm still on the search for a good anvil locally and will probably wind up buying the smaller Nimba when I can.
I'm set up with most of the other gear I need... wire feed welder for high carbon, blown horizontal forge (plans to build controlled blown vertical forge next), angle grinder, surface grinder attachment, kiln for annealing. I know I'll most likely need the better controlled forge for stainless and I assume a tig welder setup. As mentioned I'm going to start with high carbon until I have that nailed down.
Please feel free to post anything that helps or your thoughts on the process in general! I appreciate the discussion.
