- Dec 17, 2017
Wich stainless steel do you recommend to start working with stainless steel?
I already have a homemade HT kiln with PID controller.
In theory My PID and thermocouple can go over 1200ºC. I've already made a test that reached 1100ºC.what temp does your kiln go up to? also can you cryo? these may depend which steels you still cant do if any. I hear AEB-L is a good starter so that's whats heading my way now.. Also got some S35VN..
I think will will not need to worry about the furnace/kiln. As I told in a previous post I want to avoid cryogenic threatment, if possible I would prefer a stainless steel that can be quenched in oil.Powder type steels , like the CPM types , will be more costly so keep to the simple ones . VG-10 and similar 690 are very good but choice also depends on type of knife. 440 A gives the best performance but 440- B will do well also. Look at 154CM for a good choice. Make sure your furnace will handle the temperature well
Yes, I'm in Europe. I'm from Portugal.I don't know where you're located. But if you're here in Europe, I would recommend 14C28N, which is available in a lot of dimensions at a pretty low cost. And it's pretty easy to heat treat and I like its performance.
https://www.materials.sandvik/en/pr...ife-steel/hardening-guide/hardening-programs/
