Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
Don't feel bad about making changes in the materials and procedures. We are all tempted to try our ideas first...sometimes they work, and sometimes they don't.
A while back, I had a fellow in a remote part of the former USSR emailing be about building a forge. He said that he couldn't find Satanite, but found bags of a refractory cement rated at 1600°C ( about 3000°F) in an abandoned foundry nearby that had no guards or gates. All the locals scrounged metal and things from it. He also said no one knew what they used to make there, as it was a "state secret". All the workers had left when the plant was closed in the 1980's. I advised him against using things from such a place, but he said everyone went in there and no one had got sick.
I said that the refractory sounded like it should work, and to make a 1" thick shell, and then wrap it in an insulating wool blanket. He could not find any insulation wool, but cast the 1" liner and tried to use it alone.... it cracked. Then, he decided that if the refractory was good in a 1" layer, a solid refractory liner would be great. He cast the entire forge as a 4" thick cylinder of refractory by putting two concentric pipes together and casting the cement between them. Problem was, it wasn't up to temp after an hour running the burner on high.....and the outside got HOT. Luckily he was using a waste oil burner he made from an old fuel oil burner that ran a boiler, so the fuel cost wasn't a problem.
After some back and forth, he wrapped the thick shell inside a 4" insulating blanket he came up with ( he took this from the foundary,too....God knows what it was made of - probably asbestos), and wrapped a sheet metal casing around it ( also scrounged from the mill I am sure).
The forge took a very long time to soak to temp, but sure held its heat once up to temp. Not the best idea, but it worked out in the end. His forge ended up looking like some sort of old time mortar, about 20" long and 20" wide, with a 4" hole in the middle....and weighed a couple hundred pounds.
