Stainless steel washer - For 3/16 Pivot
Feedback: +142 / =1 / -0
For sale are pivot washers designed to replace the standard Teflon washers and for builders who want the best in performance.
These are designed to fit any 3/16"(5.0mm) pivot pin in any folding knife or balisong on the market. These washers were built from 304 stainless steel.
Available sizes are:
X1 = .500(12.6mm) OD * .197(5.0mm) ID * .018(0.46mm) THICK
X2 = .500(12.6mm) OD * .197(5.0mm) ID * .018(0.48mm) THICK
X3 = .500(12.6mm) OD * .197(5.0mm) ID * .020 (0.50mm) THICK
X4 = .500(12.6mm) OD * .197(5.0mm) ID * .020 (0.52mm) THICK
X5 = .500(12.6mm) OD * .197(5.0mm) ID * .020 (0.54mm) THICK
X6 = .500(12.6mm) OD * .197(5.0mm) ID * .022(0.56mm) THICK
X7 = .500(12.6mm) OD * .197(5.0mm) ID * .023(0.58mm) THICK
X8 = .500(12.6mm) OD * .197(5.0mm) ID * .023(0.60mm) THICK
As you can see, the thickness differs from 0.46mm to 0.60mm. Please specify the thickness you'll need if any, or I'll send them out randomly.
Price is $10TYD for 20 pieces/ 10 sets
Thank you all for looking!!!
Are these still available? And if so, do you think these would work as a bearing race for a knife with a 3/16 pivot?
