On some folders the bolsters are held in place by a small internal rivet not seen from the exterior. This rivet goes into a blind hole on the part of the bolster that will contact the liner. In any event I have been trying various method and I think I have it. Drill a shallow 1/16" deep blind hole. Drive the rivet/pin into this hole. Now use a "setter" to dimple around the pin to push metal against the pin and hold it tight. I used a needle file- pointy tip to dimple and VERY lightly tapped the butt end of the needle file. This set the pin so tight I can't pull it out. The protruding pin goes through a hole in the liner and is peen hammered to hold bolster to liner.
I realize some of you folks are probably thinking...So what, everyone knows that, but I didn't know how to hold a bolster to a liner before trying this method.
