- Apr 8, 2014
What I did is run the bolt thru the threads in the plate and then lock the bolt on the outside with a nut. This allows me to set the lash between the bearing and plate so your not putting a side load on the bearings. This requires threads in the plate. Thus the reason I suggested the nut on the inside. I suppose you could leave a little lash and use a nyloc nut.
