Thanks. I've been researching upgrading the platen on the Dayton. Been noticing it flexes a little bit more when it's been running for a while. Also, I don't think it's totally dead flat. Tested a piece of wood and looks like it's proud in the center just a fraction. A square isn't absolutely perfect. Anyways, while practicing, learned light pressure is key! The more I try to jam it into the belt, the uglier it is.Your grinds look waaaayyyy better than mine did. I still cant do 3/4th grinds for crap. Im just going to play the disabled and crappy harbor freight platon card now. XD
mywhitewolf4 by Dave Hamilton, on Flickr
mywhitewolf3 by Dave Hamilton, on Flickr
mykabar3 by Dave Hamilton, on Flickr
mykabar4 by Dave Hamilton, on FlickrOh I got my list man! will be upgrading the platen with steel and glass, completely rebuild that piece of crap. all steel work rest as well.Im getting a palmgren 2x42 for my next grinder. You can buy ceramic platon covers that cut down on heat and should be perfectly flat.
Thanks for the tip Marc, once I get my file guide I'll grind down the tang a little to clean it up and add a slight radius. I cut out the blank early on then learned that partDave, I noticed in your post above (#24) you have square corners where your tang meets your ricasso. This is no bueno. Square corners are stress risers and can lead to the knife failing at that location. Leave a small radius in those corners to distribute stresses.
I am attaching a "WIP" of a Bowie build by Will Morrison that contains very useful information and GREAT Photos of the build. I highly recommend this to beginners because of the depth of the information provided. Hope you find answers to many questions.Designing the guard and handle shape now and have a question. The width of the guard and where the handle meets it when looking down the knife's spine, is there a good starting point on the width? I'm starting at 1" but that looks a bit too wide, making the handle look too far at the swell, 1.25".
mywhitewolf5 by Dave Hamilton, on Flickr
mywhitewolf6 by Dave Hamilton, on Flickr
mywhitewolf7 by Dave Hamilton, on Flickr
2021-01-17_05-15-28 by Dave Hamilton, on FlickrThat looks pretty good for a second knife. I'm relatively new to knife making, but one thing I have discovered is that a lot of the "cleaning up" of the scratches and grinding mistakes can happen at 120-220 grit. A mistake happens so fast and gets relatively deep at 36 grit. Then it can get worse when you try to fix it at the same grit. But if the rest of of your work is fine at that grit, you can fix those problems when you get up to 120 pretty easy without making new problems. You make little fixes in your plunges etc with that grit without making a mess at 120 too. So my suggestion is to clean up the blade and make things look cleaner and crisper. Still, that's pretty good for a second blade.
I know a lot of people have told you to practice grinding on mild steel, but it is fun to actually use reasonable steel and actually make a blade even with your early grinding. I did what you did. Started grinding with a jig using steel I could harden and make a knife out of.
Finally, jigs. It seems like there are people that have reasons for using them and others that would prefer not to. I use a jig so far and am getting quite nice results very quikly. I don't think you will lose out if you go either way. BUT if I were you and Marc was offering to give me pointers and he didn't want me to use a jig I would toss my jig under the bench and go for my tutorial with him free hand!![]()
