Starting Fire w/knife & fire steel
I don't know if I can describe it well enough, but here goes:
- the biggest mistake most make is to use the power of their arms to strike the spark. There is little control this way;
- if you're doing it like Bear Grylls does, you're doing it wrong;
- instead, squeeze the knife in your strong hand, edge facing up;
- hold the firesteel in weak hand, between thumb and forefinger;
- let the fingers of your weak hand touch the fingers of your strong hand, keeping the hands together;
- hold the firesteel end close to your tinder source (dryer lint and dry tinder work well, though the wax, vaseline, fatwood, and other man-made tinder starters are good too);
- squeeze the muscles in both hands, forcing the spine of the blade down along the ferrocerium rod (stainless, carbon, whatever blade steels: all work as well as another, rather it's the squared edge of the spine that's important, as another poster said). The stroke is actually very short, maybe 1/2" inch along the length of the ferro rod;
- this is worth repeating - use the muscles of your hand to squeeze, instead of stroking using arm muscles. Not only do you have greater control, and will get larger, hotter sparks (globulets of molten metal), but you will not lose control of the knife and have it slam into your tinder pile....ending up with the tip striking a rock or sand or dirt or whatever.
It takes a little practice, but those who do it this way will come along and testify to its effectiveness. Use your hand and finger muscles , NOT your arm muscles, to strike the spark. You know how if you're carving a small piece of wood, you would use your thumb on one end and the knife blade nestled in your fingers, then squeeze the muscles of that hand to make a short controlled cut? We've all done that when needed. Well, same exact principal, just a little different direction and purpose.
OK. I went to the link that CZIV posted and watched the very first video available. hehehe Do NOT do it that way. That's using arm power. Watch closely how the striker slides off the end of the firesteel and into (or almost into) the tinder pile. Well, you'll find yourself actually scattering a carefully prepared tinder pile that way.
USE CONTROLLED HAND AND FINGER MUSCLE FOR THE STROKE.
Uhmmm...there are 211 results on that link. I watched a lot of them over the summer and there are some excellent videos of guys building fires with firesteels. I guess you didn't have time to watch any of them.
Here's one just right for you. :)
[YouTube]slPk-_-n2zc[/YouTube]
I think the striker that comes with the firesteels usually sucks at throwing good sparks, i throw mine out. I use the spine of one of my carbon steel FB's and usually a veseline-soaked cotton ball or drier lint as tinder-helper from time to time. Get fairly close to the tinder and run the (sharp edge of spine) spine of the knife down the rod. Like another poster said, you don't need to use a lot of power on this.
The steel also doesn't need to be carbon. All hard squared knife spines will work. Even a rock will work...
:thumbup:
:thumbup:
That's what I learned in the W&SS sub, and my own experience seems to support it. The best striker I've ever used on a firesteel was my Fallkniven F1...420 J2 steel, IIRC. That thing would throw beastly sparks that bounced :thumbup:
Well Cziv, it isn;t that I didn;t have time, rather, I didn;t take the time to watch them. I watched the first one only to offer an example of the least effective way to use the firesteel. There could well have been several good videos further on down. That first one shows the fellow using his arm muscles to stroke the firesteel and, while his striker misses the tinder pile and the fire ignites well, if you have used a ferrocerium rod you would agree that it doesn;t always work so smoothly on the first strike. Your posting that link was fine and was a good thing for the OP. My problem was only with the first video.
The OP asked the best way to use a firesteel, so I tried my best to explain how to do it using controlled hand muscles, in order to not damage the knife tip, scatter the tinderpile (have we made a fire in cold weather in less-than-ideal conditions?), or produce an ineffective spark. Using a controlled stroke is the best way to use the ferro rod. Ideally, the knife spine travels only about 1/2" and the knife (or any other striker tool) never leaves the end of the rod or otherwise loses contact with the firesteel. More power is forced into the ferro rod producing a hotter set of sparks because the "chunks" of ferro are larger, hotter, and longer burning.
Hahahaha, wicked! :D
That's how I'm starting fires from now on...Fuel and Fireworks :thumbup:
