Something designed for the job. Good luck to you sir and welcome.
http://www.knifeworks.com/index.asp?PageAction=VIEWPROD&ProdID=5044
Detailed Description
Sable IV
The Sable has one of the most practical and versatile of all the blade shapes. The full thickness of material on the back edge makes it a strong knife and the high grind and belly the blade offer a perfect utility knife which can double for most skinning tasks.
Each knife is made from a solid billet of A2 tool steel. This method results in two distinct advantages-the strength/weight ratio is exceptional and there is no handle/blade join. This means that there is no area where the blade and handle could come apart. A2 Tool Steel offers excellent edge retention and good shock resistance Hardness at between 55 and 57 Rockwell C is not brittle but gives good edge retention along with ease of sharpening.
Specifications
Blade material A2 Tool Steel
Blade hardness 55-57 RC
Blade coating KG Gun-Kote
Blade length 5.50" (139 mm)
Blade thickness 0.197" (5.0 mm)
Overall length 10.50" (266 mm)
Weight 10.5 oz. (297 g)
Sheath 5.5" wraparound, leatherr
Handle material A2 tool steel
Butt cap material D65S aluminum
Or this one in a similar vein. The sheath might be better for fixing to webbing.
http://www.knifeworks.com/index.asp?PageAction=VIEWPROD&ProdID=5046
Shadow IV
The Shadow series was designed to incorporate the two basic criteria needed in knives destined for hard field usage - plenty of blade weight and good strong points. This spearpoint design has been used by professional soldiers all over the world who have found them to be extremely good weapons as well as rugged dependable tools. The Shadow III is a good everyday carry knife and the pancake sheath rides high and snug. The slim, symmetrical sheath supplied with the Shadow I and Shadow IV has a strap which snaps over the cross guard and that can be moved to allow left-to-right or right-to-left closure.
Specifications Shadow IV
Blade thickness 0.187" (5.0 mm)
Weight 11.50 oz. (326 g)
Sheath 5.5" snap, leather
your choice is good too
http://www.knifeoutlet.com/shop/catalog/5401.htm
Have you considered any Busse knives?
http://www.bussecombat.com/
and in particular the quality of the blades
http://www.bussecombat.com/infi/
Edited to add that the Forum's Greg Covington makes combat blades (as do others). This is his offering
http://www.covingtonknives.com/combatspec.htm
