You need to provide a ground path between the grinder and your body. When it is cold and dry (fairly rare in Tidewater) and the static is bad, I have a 4' piece of light weight chain (from an old dog leash, but any wire or metal chain will work) that has an alligator clip on both ends. I clip one end to the grinder base plate and the other to my belt. That is much safer than clipping it to the blade, which might get in the way. If you forget to un-clip it and walk away, the clip will just pop off on one end or the other- no harm. Of course your equipment should be properly grounded and wired right, to avoid getting the other kind of shock.
Stacy
