Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
There have been several threads about the static discharges from grinders on cold and dry days.
The buildup is in you. As your knife blade rubs against the belt, it loses electrons. Since you are connected to the knife, the missing electrons are replaced with ones from you. Normally new ones would come from the earth (ground) and replace them. When it is cold and dry, that is not as fast and easy, so you become positively charged. When there is a path for the differential to neutralize to ground ( moving your hand near the grinder frame), a bolt of electrons jumps from the grinder frame to you to replace the missing ones. Lightning is the same thing, just many million times stronger. A Van DeGraaff generator works exactly like your knife and the belt.
Using a proper ground strap is not dangerous. All you need is a 1 megohm resistor in the line. An alligator clip, a piece of stranded wire, a 1 meg resistor, and a short piece of light weight chain will take care of the problem safely and completely.
This has nothing to do with a bad ground on the motor, or shorts, or wiring.
Stacy
Stacy
