Steel Composition question
navman
Moderator
All,
At last year's BLADE I purchased two bars of beautiful ladder pattern Damascus from Gaston Glock. At the show, I asked the guys at the booth what the composition was so I could request an accurate heat treat protocol from Brad at Peters'. I never heard back.
http://www.gastonglockstyle.net/damascus-steel.html/
The billets are the LEOPARD IV tank barrel Damascus. Anyone have any idea what the cutlery steel is that was used in these?
Cheers!
Found this on their site.
With proper heat treatment, the hardness of this steel is about 63HRC, and is thus harder than glass.
Hardening is done in a vacuum or with inert gas at 850 degrees, with a retention time of up to 5 minutes.
The cooling rate is equivalent to that of an oil hardening. For the conversion of retained austenite, either a freezing process at 90 °C or a tempering process at 140 °C takes place.
Next, a tempering process at 150 °C should be carried out to assure the complete transformation of retained austenite to martensite.
Saw that as well, the site says that in addition to the tank barrel, the smith used bearing steel and cold work tool steel...pretty vague.
Thanks Warren!
looks like the primary steel is 1.2842 (AISI O2 steel). Blade should perform well. I plan on making some small skinners for retirement gifts.
