- Jan 10, 2015
So I hesitate a bit to open this up, but here it is. Is this a real thing or voodoo?
OUR BARREL MAKING PROCESS
We utilize a "pull-button" rifling process to make our barrels. This involves pulling a precision ground hard carbide tool, called a "button," thru a drilled and reamed hole in the barrel blank. This button is larger than the reamed hole and therefore displaces steel to form the groves and lands of the rifling. This process results in a very uniform surface that is hardened as a consequence of the compression of the steel and "work hardening".
