Ok, so recently I've started hearing that steels are actually easier to sharpen if they are higher gen and therefore finer grain. For instance elmax is 3rd gen, so it's easier than s30v which I believe is first gen.
My question is: what are steels like s90v and s110v , since they are so hard to sharpen? Are they lower gen steels or with those does it come down to the sheer volume of vanadium in the steels (extreme wear resistance)? A combo of both features maybe?
My conclusion so far:
If I understand correctly, without the PM process to factor in, the higher the abrasion resistance of the steel, and the harder its run at, the harder it is to sharpen. Then when you factor in the PM process, you still have those two factors, but the steel becomes easier to sharpen because of the finer grain. So it would make sense that a steel with more wear resistance but the same 3rd gen process as a less wear resistant steel, would be relatively harder to sharpen. Am I right?
