Everyone and their companies define is so they look best. But the actual processes are described below. Read the information and not the marketing.
Source: http://www.spyderco.com/forums/showthread.php?50603-Powdersteel-generations
A: From one of Carpenter’s R & D managers: “The first generation powder product that was originally produced in Sweden by Erasteel and Anval (now CPP AB) consisted of air induction melting in a top pouring furnace followed by pouring the molten metal into a tundish from which the molten metal is bottom poured out of the tundish and is atomized to produce a coarse powder, typically -1000 microns or -500 microns.
The second generation powder product as practiced by Erasteel, CPP AB, and Böhler, consists of the first generation air induction melting process followed by pouring the molten metal into a heated, refining tundish called an “ESH” tundish (Electro-Slag Heated tundish), where the molten metal is heated with graphite electrodes (Erasteel and Böhler process) or a plasma torch (CPP AB). The refining tundish permits the molten metal to be purified (reduce the amount of inclusions). After refining, the molten metal is poured out of the bottom of the tundish and is atomized to produce a coarse powder, typically -1000 microns or -500 microns (the same powder size as the first generation process).
Böhler’s third generation powder product consists of the second generation process followed by a modified atomization process that produces a finer powder, typically 250 microns. Böhler claims the finer powder reduces the presence of coarse carbides compared to the first and second generation, coarser powder.
As noted above, CPP AB uses the second generation powder process. CPP BVL (BVL is our facility in the US and our source for CTS 204P) uses both air induction melting and vacuum induction melting coupled with the use of reticulated refractory filters in its tundish to produce 150 micron powder (finer than Böhler’s powder) for P/M tool steel millform products. CPP BVL’s powder manufacturing process does not directly compare to the European classification system of “first, second and third” generation powder processing. BVL’s vacuum induction melting + filtration process plus the use of -150 micron powder is cleaner than the third generation process. The air induction melting process + filtration process plus the use of -150 micron powder is equivalent to the second generation process with a finer powder than the second generation process.”
From Ron: As you can see it is not exactly an “apples to apples” comparison when one puts the processes side by side.
Effectively, from dimensional perspective, our “2nd generation” process produces a finer, 150 micron powder than their “3rd generation” process which is 250 microns. And I don’t believe they would argue that their 250 micron material would have finer carbides than our 150 micron material.
The other issue is product cleanliness. I have asked for information on product rejection rates for inclusions and have yet to find an example. I am not saying they do not happen; just that folks are having problems finding the last time it did happen. In my short tenure here I have not dealt with an inclusion. I will look to get you a better definition of cleanliness relative to our product.
Regards,
Ronald Long
Carpenter Technology Corporation
Commercial Manager- Knife Blade Products
Regards,
Ronald Long
