- Feb 19, 2007
And INFI is
C=0.5
Va=0.36
Cr=8.25
Co=0.95
Ni=0.74
Mo=1.3
N=0.11
Not really too close. But we may hope it will be great steel also.
Other Nitrogen steel is xn15-TN
C=0.4
Cr=15.5
Mo=2
V=0.3
N=0.2
Known for extreme rust resistance...
What HRC will it be?
Looking forward to see this steel!
Thanks, Vassili.
Hi Vassili,
The recommended hardness range for 14C28N will most likely be 55-62 HRC, like for 13C26.
I believe also S30V and H1 contains nitrogen, together with INFI and X-15TN that you mention I believe they are all covered.
Vassili, do you know why they put nitrogen in INFI? Normally nitrogen is used as a hardness driver (instead of some carbon) but without the negative contribution to corrosion resistance that carbon brings. But INFI cant be stainless at all anyway, so why bother? Do you have any idea?
X-15TN is an interesting grade in my opinion, maybe the hardness potential is slightly low for knives but it's an interesting grade. I believe that the nitrogen content is slighly lower than 0.2 % though, like 0.15% (from the name X15-TN), I might be wrong though. I have seen in some steel charts from knife makers that they list X15-TN as 0.2% but I seem to remember that we went through their patent on that grade and it said 0.15%. Well it doesn't matter, the nitrogen in the X15 is there for corrosion resistance that much is clear.
Regards
//Jerker
