- Dec 25, 2004
I've been seeking a company with a good dimensions of 440C but in my country it is impossible so i decided to find alternative SS steel. And I found RN15X in 5mm thick ( 440C's were at least 4,5 cm = 45mm ~.8 inch ). Here is the specs of this steel : RN15X.
I am used to forge, stock removal and HT of D2(DIN 1.12379). It is by comparison much more corrosion resistance (D2 is mostly enough for me but for scuba knife it rust as easily as O1 in salty water).
What do you think of it? Do you think it is OK for Kitchen and Scuba knives. I have at least 3 Scuba knife orders and I'm in a hurry to order something...
PS:
Quote from http://ctklj.ctk.uni-lj.si/kovine/izvodi/MIT036/serak.pdf
"the presence of niobium increases the content of vanadium in the solid solution after austenitizing, and consequently a higher secondary hardness is obtained. In steels containing a mass fraction of more than approximately 2 % Nb, coarse NbC+g quasi-eutectic regions are formed 8. These regions are very stable and do not change during high-temperature heat treatment. The presence of these regions in the microstructure is deleterious because they affect the brittleness of the steel, but by using a powdermetallurgy process they can be prevented. In order to achieve an alloy with maximum hardness it is necessary to find the optimum heat treatment for the steel."
PS:
