Interesting responses on file guides here.
You guys should see my first one, it’s made from 52100 and has no pins at all. It’s has no carbides either and is so out of square and half ground away its ridiculas
As a knifemaker I can’t be making file guides so after the first ones our son-in-law Benton needed to pay off bills after he married our only daughter Krista. He made them the way I taught him and they worked pretty good but about 3 years ago I gave the fileguide job to our oldest son Brian. Brian is an artist and my favorite engraver. Brian took them to a whole new level with each batch of 50 or so. He lives in Salem/Turner Oregon and has a local CNC Machine shop do much of the work so the tolerances are super tight now. The pockets are so close to the carbide size that there is very little epoxy used. The pins are hardened carbon steel so there is a natural frictionless smoothness against the 303 stainless steel frames.
The carbides need to have a very small gap so they are not allowed to touch the blade. Carbide does not flex and if they touch the blade could break when tightened down.
Prices have creeped up from my original $75 to $155 because of out-sourcing and inflation. Cheaper ones are out there. I get one back once in a while and refurbish them here in my shop for about $40 good as new save for some hammer marks and massive metal missing.
The carbides are only 1/4” for reduced price plus It’s easier on the file with less carbide to file contact area. I haven’t experienced the need for a wider carbide.
I,m not peddling fileguides on here, really but I am proud of my team for moving forward with quality with each batch
Check them out at brucebumpknives.com
I've been planning to make some for a while that exceed the others, in the areas I've mentioned, but with hardened bodies that can be used for actual filing, with the non-carbide side, in wider configs than the Riverside. Maybe it's time I get around to that.
