Thanks again Cliff -
here's a quote from a sharpening instructional article that has become legend and a reference on the net, it supports BOTH the use of a smooth steel and a ceramic rod -
ref:
How to Sharpen a Knife tips from an old meat cutter
by Dee Griffin, DVM
University of Nebraska, Great Plains Veterinary Educational Center
QUOTE:
KEY POINT: "THE STEEL".
Using a "Steel": As many blade edges are damaged by steels as are improved. USE A SMOOTH STEEL, WITH A CAREFULLY DIRECTED LIGHT TOUCH.
A steel has aligning grooves designed to straighten an edge. I think it is better to lightly pull the defects back into proper alignment than to push them into alignment. This is accomplished by using a pulling stroke (pulling up from the handle away from the cutting edge). After the edge has been realigned, a light down stroke (pushing the edge into the steel) will firm the cutting edge. Be gentle, a hard whipping stroke can wreck an edge as fast as anything I know.
Steel come in four cutting types: Course Cut, Regular Cut, Fine Cut and Polished - No Cut. Course and Regular Cut Steels seem to be everyone's favorite
everyone except those who make a living with a knife. Packing house workers use a very smooth (polished - no cut) steel for most of their knife blades cutting edge maintenance. You will notice them polishing their steel frequently with an emery cloth (180 to 400 grit). The emery cloth helps keep the steel smooth and the small grooves in the steel aligned. A course-steel has very distinct aligning grooves. When a blades cutting edge is used harshly against the deep grooves in a course steel it can cause the cutting edge to chip. The little nicks left in the edge will make the blade seem sharper for a few cutting strokes. The nicks soon wear down and repeated attempts to steel the knife sharp will be futile.
THE CERAMIC ROD AS A STEEL: I love ceramic rods to touch up cutting edges. I use them like a steal using a soft light touch. Note: Ceramic rods are very fine (>1200 grit) abrasives therefore do more than straighten edges.
THE GRIP: Hold the steel as if it were an extension of your arm (stiff but dont over grip). If held to tightly, the reflex action of the opposite stroking hand if often too firm against the steel. This will cause blade damage.
THE STROKE: When stroking a steel, avoid twisting your wrist or elbow
keep them stiff. Learn to use the motion of your upper arm and shoulder, rotating your knife hand as you stroke each side of the blade. Keep Your Eye On Your Thumb! Watching the thumb nail of the stroking hand will allow you to develop a consistent angle on each side of the blade as you rotate your wrist.
The angle of the steeling stroke is just slightly greater than the CA you set on the knife (approximately 30 degrees for a 25 degree CA).
Learn to feel for defects in the blades cutting edge.
You can feel the small bent or damaged areas in a blade edge. A pulling stroke or back stroke against the steel is the gentlest approach to a steel. Use the steel to straighten the small bent areas in the blade, not break them. A course-steel will straighten severely bent areas on an edge. If you abuse these areas with the course steel, the blade will require reworking.
Care of a steel:
Most Steels have no chromium, therefore they will rust. I clean, dry and oil my steels after use. NaOCl (bleach) will pit low or no chromium metals such as steels and some knives.
UNQUOTE
Vincent
http://UnknownVincent.cjb.net
http://UnknownVT.cjb.net
